How to view 3d picture scenewindow in fullscreen?
I would like the scenewindow that renders a 3D picture to enter fullscreen mode (as opposed to a maximized window).  Is this possible?
Joe
(2,636 Views)
Hi Joe,
You can use property nodes to make your application full-screen, and the "scale object to pane" property of the 3D picture control to resize the control as the front panel size changes.  I've attached an example of how to do this.
(2,617 Views)
Thank you.  Although the scene is still in 'windowed' mode, if you get rid of the taskbar at the bottom it's equivalent.
-Joe
(2,610 Views)
