How to view a block diagram in labview 4
i need to know just how to get my block diagram up using labiew 4
(23,898 Views)
From the menu bar on the front panel, select Window >> View Diagram. If that option's not there, the VI was saved without a diagram so you won't be able to view it. Saving a VI without a diagram is an option which can be used when you distribute your VIs so someone else can use them but not see or alter your code. If your copy was saved without the diagram, try to find the original with the diagram.
(23,898 Views)
Sorry: it's actually Show Diagram (not View). Anyway, just based on the fact that you asked the question, I'd guess the VI was saved without a diagram.
(23,898 Views)
