How to view multiple output parameters from web services
I have used the Labview tool to create a .NET assembly from a WSDL file.
In the WSDL file the service has been defined to return 2 output parameters.
In Labview, when I invoke the method for this service the first output parameter ends up as the return value of the method.  I can create an indicator for this and it gets updated properly when I run the VIS to use the web service..  The indicator is an integer value but recognizes the type defined within the WSDL file.
The second output parameter shows up as an output value.  When I right click on it and create an indicator for it I get a .NET icon on the front panel rather than an integer value.
How can I view the value for this second output parameter after running the web service?
Is there a difference in how multiple output parameters handled in newer versions of Labview (I am using verison 7.1)?
Message 1 of 1
(3,908 Views)
