choose to wirte to file
Hello
I have a vi program as the attachment.
Is it possible that after the user runs the programming many times and choose to save all data?
cynitha
(3,098 Views)
Besides, is it possible to create a table in which the first column is for the user to key in data, and the second column is for the result of the running program?
for example,
This column is for the user to key in data
This column is to put in the data from the program
thanks!
cynitha
(3,096 Views)
Hi cynitha,
yes it's possible. Can't open your vi, because i don't have 8.6 at the moment.
Mike
(3,089 Views)
please see the attachment for the block diagram
thanks
cynitha
(3,080 Views)
Hi cynitha,
can you please explain what you try to do? When and where shall the user insert the data for the first column?
Mike
(3,078 Views)
Thanks for quick reply, Mike
I hope to have a program in which the first column is for user to key in data, the second column shows the count, and the third column shows the elapsed time.
Is it possible for remote user to choose when to save the data. I mean, save the data after run once or run ten times?
cynitha
(3,049 Views)
