How to visualize one or more zero references on a graph
In my application, I display 4 signals on a graph. In order to have a simpler interface, I'don't display any scale on my graph.
I would display a zero reference for every signal. For zero reference, I mean a small cursor, or arrow, or other that indicates the value 0, like in the oscilloscopes.
Can you help me?
Thank all
(2,893 Views)
You could turn on the scale but only have one marker at 0. I don't remember off hand what it's called, but you can have a scale where the only markers are the ones that you explicitly add to it. I have used it in the past for things like SPC charts where the customer wanted markers on the control limits, and 0.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,890 Views)
But I need of 4 different zero references that move along the left side of the graph. Is it not possible to have a cursor like the needle of the slide indicator?
Thanks all
(2,875 Views)
Accepted by andcadev
Hi Fourier,
create cursors for your graph(s) and set them at 0,0. Set their appearance as you like (with or without (dashed) lines, no/small/big cross, etc.)!
(2,873 Views)
