10-31-2016 04:36 PM
Here's a couple links that came up when looking for TextBoxes in LabVIEW, both are pretty simple examples.
https://decibel.ni.com/content/docs/DOC-9151
http://digital.ni.com/public.nsf/allkb/4FB2B40E6501AEF6862574FF00595878
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
11-01-2016 08:50 AM - edited 11-01-2016 08:54 AM
Hi aveter,
I have a suspicion that your "Application Font" size isn't the same as what is used in the text box. The "Get Text Rect.vi" uses the default application font size in its calculation if an input is not wired, which I see from your screenshot is set to 17 pt, whereas the textbox looks like the default 15 pt.
Supply the actual font used by the text box to "Get Text Rect.vi" and you'll align the text as close as possible without setting its font to monospace:
I agree with the other posters on the awkwardness of this solution and the burning need for something more elegant.
