How to well-aligned print a 2D string array to a textbox?
Message 11 of 12
(1,164 Views)
Hi aveter,
I have a suspicion that your "Application Font" size isn't the same as what is used in the text box. The "Get Text Rect.vi" uses the default application font size in its calculation if an input is not wired, which I see from your screenshot is set to 17 pt, whereas the textbox looks like the default 15 pt.
Supply the actual font used by the text box to "Get Text Rect.vi" and you'll align the text as close as possible without setting its font to monospace:
I agree with the other posters on the awkwardness of this solution and the burning need for something more elegant.
Feel free. Contact me for anything more,
    Pang
You too can be LabVIEW Awesome!
Message 12 of 12
(1,147 Views)
