How to wire Time signal in sequence loop? (from Matlab Fractal Example)
This might be a simple question, but it stopped me a few hours so I am asking for your help.
My question is how to create that blue arrow?  Any help would be appreciated!  Thanks!
(2,842 Views)
First you have to have a stacked sequence.  Then you popup on the frame and select "Add Sequence Local".  This will create an empty box.  Then once you wire into it with an int or uint it will become a blue arrow.
If you have a flat sequence, you don't need one to be able to move data from one pane to the next.  It also won't let you move data backward, so the "in"s execution must be before the "out"s execution.
Hope that this helps,
Bob Young
(2,834 Views)
Got it figured out.  Create a Local variable. Add sequence Local, to be exact!
(2,834 Views)
