09-12-2005 04:58 PM
09-12-2005 05:09 PM
First you have to have a stacked sequence. Then you popup on the frame and select "Add Sequence Local". This will create an empty box. Then once you wire into it with an int or uint it will become a blue arrow.
If you have a flat sequence, you don't need one to be able to move data from one pane to the next. It also won't let you move data backward, so the "in"s execution must be before the "out"s execution.
Hope that this helps,
Bob Young
09-12-2005 05:11 PM
