How to work with arrays when building a CIN?
I need to develop a CIN which takes in 1 3x3 array along with a couple of doubles as inputs and outputs one 3x3 array. I am completely fine with building the block diagram in LabVIEW and generating the .c file, the problems begin to occur when I need to handle the input data inside the function! I have no idea how to access each particular element of the array!?!? The input parameters show as something like this : TDIhl(this might be mispelled) Array1, ...Array2... and so how would I access say element in row 1 column 2 of Array1??? Is there any array functions to use with a CIN? Please as much help will be appreciated,
(2,738 Views)
Why do you need a CIN? Can't it all be done in LabVIEW?
(2,738 Views)
The code is written in C. There are alot of complex manipulations of the input data (data conversion, math equations, etc..) I have code in C so it's alot easier for me to try to adjust the code to fit the labview data types vs. I'm not even sure what? I am just a beginnner when it comes to LabVIEW. So please humor me and answer my original question,
(2,738 Views)
For an array with "r" rows and "c" columns, you can access the element at row "i" and column "j" as follow:
value = (*array1) -> arg[i*c +j];
For more information, check the document "Using External Code in LabVIEW", which should be included with LabVIEW. You can download the document also from www.ni.com at:
http://digital.ni.com/manuals.nsf/web_productcurrent/4F1447F7CD83D6D88625690D00637CED?OpenDocument
Also, check the following example at the developer zone:
Replacing a Portion of an Array
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&3B5B43568CF83D948625683A000C397E&cat=71359FBAD517F4CB862567E0007B6F6E
Best regards;
E. Vargas
www.vartortech.com
(2,738 Views)
