How to write a feedback loop or shift register to toggle a boolean during while loop
I have a sensor constantly reading values during a loop, and I need to have a boolean toggle to 1 when a maximum value is reached, and then to 0 when a minimum value is reached. I will be reading a sinusoidal pressure measurement and it is important to know if I am on the ascent or descent. For instance, let's say min: (less than or eq) 2, max: (greater than or eq) 5. The issue I am having is that I am a novice and only able to set a boolean to be 1 if it is = or > than a value. This is an issue because a value of 3.5 could have a boolean of 0 or 1 depending if it is in the ascent or descent. I'd also strongly prefer not to read the slope real time to determine this, as I don't think it would be accurate and reliable.
I'm sure this is very simple to an expert, does anyone have a vi that can do this?
(2,908 Views)
Yes, it is very simple, but we can help better if you show us your failed attempts (attach your broken VI!), so we get more context. Nobody wants to start from scratch with too many vague points. 😉
(2,899 Views)
@altenbach wrote:
... too many vague points.
Some vague points:
  • What is continuously?
  • What is the typical noise?
  • What is the amplitude and range of the measurement data?
  • So the signal is approximately sinusoidal. This is important information. What lets you conclude that the slope changes exactly at one threshold? With noise, it could continue to go up for a few points or never reach the value, but still go down after getting very close.
  • What is the frequency of the sine compared to the sample rate? (many points or just a few point per period?)
(2,883 Views)
    • SPI pressure readings
    • Very little, but I would like to modulate it by the last peak measured
    • In this case, 0.05-0.12 PSI
    • I am using a microcontroller to open and close an entry valve downstream of a gas pump and an exit valve exposed to atmosphere to achieve the desired pressure waveform (I am creating a small pressurized incubator to study hypertension in cells. I am recreating the pulsatile nature of blood pressure)
    • So to be clear, I am creating a sinusoidal waveform, not simply observing one that I assume to be there
    • Sampling rate is roughly 160/sec
Here is a rough waveform that I have obtained as well as my VI (although it is quite messy)
(2,871 Views)
Of course cause and effect is not quite clear. I assume the slope changes sign because the new measurement is out of range (above or below). Basically we are dealing with a simple on/off control with a deadband. I think there are quite a few examples here. Just do a search.
Maybe the attached will give you some ideas..... (Many things can probably be simplified)
(2,864 Views)
It's certainly not out of range, my sensor is accurate from 0-5 PSI, and I can precisely control my solenoid valves to maintain this. I have also validated it with other sensors. My only issue  is that I can't write a code that doesn't rely on using 2 loops.
(2,827 Views)
Why not and why do you think you need two loops?
I meant outside of the desired control limits, forcing a change in boolean.
(2,811 Views)
