I am trying to read a simulated AO Voltage with a simulated AI card but am unsuccessful
I am trying to simulate what capturing a waveform on the AI card (PXIe-4300 simulation) would be like by simulating that waveform with a PXI-6738 AO card simulation. I simulated these cards in NI Max
By following  another thread (Reading the Value of Analog or Digital Output Channels in LabVIEW and LabWindows™/CVI™)
on using the internal channels I have tried to route the AI DAQmx to the AO channel I am using but it does not seem to be working.
I am attaching my code, I am also not even sure this is possible.
When I run the code I expect to get the same waveform in the "measured output" vs the "theoretical output" but this is not the case and this is why I say it is not working.
Thank you
(1,954 Views)
Accepted by topic author NISPACE
Hi, I think this is an expected behavior. Please check following topic.
Can I route signals on a DAQmx simulated device?
Certified LabVIEW Developer
GCentral
(1,918 Views)
Though the linked thread is pretty old, I can confirm that the answer is still true.  Simulated devices don't have *that* level of sophistication for simulating specific data or task interactions.
Consider adding your kudos to this excellent suggestion on the Data Acq idea exchange.  Those kudos get considered when NI plans out the new features to add.
-Kevin P
(1,884 Views)
Thank you for the response!
(1,868 Views)
