How to write comma delimited numbers to configuration file
In the attached Write Configuration File.vi, I am trying to overwrite several comma-delimited decimal integers in Keys 1 and 2 of the attached Test.ini file. I am converting the array of integers into a string. Because of that, the string written to the ini file is now bracketed by apostrophes. What do I need to do to write the string without the apostrophes, as in the Test old.ini file?
I appreciate your help. Thank you.
Peter
(2,754 Views)
