02-12-2013 06:51 PM
In the attached Write Configuration File.vi, I am trying to overwrite several comma-delimited decimal integers in Keys 1 and 2 of the attached Test.ini file. I am converting the array of integers into a string. Because of that, the string written to the ini file is now bracketed by apostrophes. What do I need to do to write the string without the apostrophes, as in the Test old.ini file?
I appreciate your help. Thank you.
Peter
Solved! Go to Solution.
02-12-2013 07:00 PM
