How to write <Cntrl> Z to the port
For an operation i want to write <Cntrl> Z on the port. Kindly tell me what should i write.
I have send ^Z but it's not working.
(3,214 Views)
You can calculate the Ctrl code using this formula
(ASCII_code(x)-ASCII_code(A))+1, The ASCII code for A in decimal numbers is 65.
Some examples
<CTRL>A= (65-65)+1=1
<CTRL>C= (67-65)+1=3
<CTRL>Z= (90-65)+1=26
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,210 Views)
Accepted by topic author Getwonder
Also take a look here
https://www.ni.com/docs/en-US/bundle/labview/page/backslash-codes-display.html
Set your string in '\' Codes Display mode. 26 is 1A in hex  then typing in hello\1A will give you a string equal to hello<CTRL>Z. A common mistake I have done several times is to type in hello\1A and NOT using the  '\' Codes Display mode. That has costed several hours of debugging. So be 100% the string control/constant is in '\' Codes Display mode
(3,199 Views)
Thank you very much to all of you.
(3,177 Views)
