playing a music
Dear all
How can I play and control a music in LABVIEW?
Thanks in advance
Muhammad Abul Hasan
Message 1 of 8
(3,592 Views)
USE SOUND VI'S .... VI'S ARE PRESENT IN "GRAPHIC&SOUND".... USE PLAY FILE VI TO START WITH & THEN YOU CAN PLAY AROUND WITH OTHER VI'S.
Message 2 of 8
(3,586 Views)
Dear
Thanks a lot for your reply. I never used this sound VIs before. Can you show me a simple block diagram so I can understand and can do more things on it.
Best Regards
Muhammad Abul Hasan
Message 3 of 8
(3,572 Views)
LOOK AT THIS AND TRY OUT, YOU SHOULD BE ABLE TO PLAY ".WAV" & "MP3" ..... IF YOU WANT TO PLAY DIFFERENT FORMAT THEN USE ACTIVE x & CALL WINDOWS MEDIA PLAYER AND PROGRAM ACCORDINGLY.
Message 4 of 8
(3,566 Views)
First of all ¨Systemcrash. You should not eat or drink while working with your computer. The keys can get sticky like your Caps Lock key are now.
In Labview it is NO functions for playing other sounds files than wav files. But you can at least in windows OS use ActiveX to embed a media player into Labview and also control it from Labview.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 8
(3,559 Views)
I believe the way I have told and way you have depicts one and the same regarding Active X,  Keyboard sticky non sticky it shouldn't bother you, if the other person is able to understand something from the reply that's enough for me.
Message 6 of 8
(3,551 Views)
Ummm.... where did ActiveX come into this? The sound VIs don't use ActiveX.
http://www.simplehelp.net/2006/08/14/how-to-be-polite-while-youre-online-practicing-good-netiquette/
To poster: there are examples that ship with LabVIEW on how to play sound files. Have you looked at them? Help -> Find Examples.
Message 7 of 8
(3,511 Views)
Thanks for the link sir.
Message 8 of 8
(3,505 Views)
