How to write "Pagedown" to the serial port?
Hi all
In my application i am communicating with the board through RS232. For selection and some other purpose we have to use the "PageDown" key. Manually we will do this in Teraterm by selecting the "PageDown" key in keyboard. I am trying to automate the whole test procedure. How can i write the "PageDown" to serial port? From event structure i got 81 as the scancode for "PageDown", i tried with this code and it failed. How can we write the extended ascii code??
please help me..
Thank You
Regards
Rajesh R.
Rajesh Raghavan Nair
Certified LabVIEW Architect
Certified Teststand Architect
(3,936 Views)
It is more easy think about strings as a  byte array with values from 0-255. In Labview you will find several modes to display/use non printable ASCII codes. Go to the help (the F1 key) search for strings and locate the "display types" section.
It is not any ASCII code for the pgdown key. But teraterm must send a ASCII code or a sequence of ASCII codes. Just hook Labview up with Teraterm and see what Teraterm send then you push the Pgdown key. Then mimic this in Labview.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,926 Views)
page down = FormFeed?
Greetings from Germany
Henrik
LV since v3.1
(3,921 Views)
Hi Rajesh,
To send Page Down to serial port use 0161 in hex format in string.
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,905 Views)
@Himanshu Goyal wrote:
Hi Rajesh,
Thanks and Regards
Himanshu Goyal
I have wasted a lot of time debugging code. Because the string indicator/control or constant was set to wrong view mode. I know Doh!...Never think you have the correct display mode check it to be sure
(3,894 Views)
If your device uses an ANSI/VT100 terminal type, you may need to send an escape code to perform certain functions.
http://en.wikipedia.org/wiki/ANSI_escape_code
Your hex string might look something like
335B 3236 54
This would be the escape key, a right bracket, the digits 2 and 6 to scroll down 26 lines and T to indicate scroll n lines (26).
(3,884 Views)
Accepted by Rajesh_Nair
Hi all
Thanks for the reply. Inorder to findout the corresponding Hexcode for "Pagedown" key, i did the following :
1.Connected the serial port of the PC with LabVIEW to another PC with Teraterm
2. Gave an input to Teraterm by pressing the "Pagedown" key
3. Observed the Hexcode through Serial Read in LabVIEW
The value was found to be 1B5B 367E and now it is working!
Once again Thanks to all of you for your valuable response.......Smiley Happy
Regards
Rajesh R. Nair
(3,864 Views)
