How to write this frequency step by using write measurement
Hi all,
I'm really really new to labview and this VST.
I believe i have created a stepped frequency signal.
I'm trying to write the output in a notepad or anything in order to be able to plot it in another machine.
Please help by pointing to the right way.
see attachment for my vi.
cheers
(2,646 Views)
Most of the subVI's are missing... Attach again along with subVIs...
Your code loks as it generates the real signal (using hardware), but if you want to write the signal(s) to notepad, you might wanna use 'Waveform Generation VIs' OR 'Signal Generation VIs'.
Waveform & Signal Generation
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,636 Views)
