How to write variables to spreadsheet file
I am running a program in the run continously mode.
One of the variables changes with time(It is inside a while loop and is a part of DAQ task).I want to record all the values that this variable takes during run time and write them to a spreadsheet file?
How can that be done?
(3,061 Views)
Stop doing that.  Put a loop around your code and stop with a stop button.  The run continuously is meant purely for debugging purposes.
Gaussy wrote:One of the variables changes with time(It is inside a while loop and is a part of DAQ task).I want to record all the values that this variable takes during run time and write them to a spreadsheet file?
Use the Write To Spreadsheet File function.  If you want more specific help, you will need to share some code.
(3,057 Views)
I am uploading a snapshot for my VI. I am creating a PID application.What I need to do is to record all the values of measured RPM and desired RPM with timestamps to an Excel sheet..so that i can make a plot of this to observe transient response.I have no clue as to how to go about doing this!nipost.JPG
(3,029 Views)
Accepted by Gaussy
Give this example a look over.  I am opening a file before my main loop starts and closing it after the main loop.  Inside of the loop, I am formating my data into a tab delimited string.  I am then saving that string to the file.
(2,995 Views)
I did the same and it worked!!!Smiley Happy
Thanks 🙂
(2,979 Views)
