How would I link a pdf file in a comment box in labview?
I have a quick quesiton....
That way if the user would want to open up my pdf that talks about lab view the can just click on it instead of searching for in the files..
Thank You,
Jack
(3,159 Views)
Lots of ways...
Command line: https://decibel.ni.com/content/docs/DOC-2204
ActiveX: https://decibel.ni.com/content/docs/DOC-2163
I am sure there are others.  Search terms = labview open PDF
(3,156 Views)
If I am working on a documentation of my VI. And I want to put it into a word document and then make it a pdf.
Is the best way to just copy and past the wires, inputs, etc. into a word document?
jakers
(3,151 Views)
Use the code capture tool to make a PNG of the code.
(3,147 Views)
I would use free labels (and possibly even arrows from the decorations palette) in the VIs themselves.  Then I would add overall comments in the VI properties --> documentation --> VI Description so they show up in the context help.
Bill
CLD
(Mid-Level minion.)
(3,145 Views)
I didn't realize this is related to this post.  I thought you did a good job of documenting it already.  🙂
Bill
CLD
(Mid-Level minion.)
(3,138 Views)
