‎05-17-2013 03:54 PM
Jack
‎05-17-2013 03:59 PM
Lots of ways...
Command line: https://decibel.ni.com/content/docs/DOC-2204
ActiveX: https://decibel.ni.com/content/docs/DOC-2163
I am sure there are others. Search terms = labview open PDF
‎05-17-2013 04:16 PM
If I am working on a documentation of my VI. And I want to put it into a word document and then make it a pdf.
Is the best way to just copy and past the wires, inputs, etc. into a word document?
jakers
‎05-17-2013 04:20 PM
Use the code capture tool to make a PNG of the code.
‎05-17-2013 04:22 PM
I would use free labels (and possibly even arrows from the decorations palette) in the VIs themselves. Then I would add overall comments in the VI properties --> documentation --> VI Description so they show up in the context help.
‎05-17-2013 04:31 PM
I didn't realize this is related to this post. I thought you did a good job of documenting it already. 🙂
