Howto remove the stop button.
Is it possible to remove the little stop button in the taskbar. I have to
make sure, the users, will use my own stop button because I have to reset
and close all the hardware.
Thanx in advance,...
Greetings,
ErX.
(5,109 Views)
VI properties-Window Appearance-Customize-Show Abort Button
"-=ErX=-" wrote in message
news:3d85747d$0$230$4d4ebb8e@read-nat.news.nl.uu.net...
> Hi,
> Greetings,
> ErX.
(5,109 Views)
Sure - right click on the VI's icon in the top right hand corner of the development system and select "VI Properties". Then drop down the box to select "Window Appearance", and click on Customize..." This will open a window where you can change many options, one of which is the "Show Abort Button" - deselect this option, and return to the development system.
Warning: if you do deselect this option, you won't be able to stop your VI by using Ctrl+. anymore, so make sure your application can stop, otherwise you may need to Crtl+Alt+Delete to get out of it!
Like my Answer? Give it a rating!
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(5,109 Views)
