external lib call exits on error, which causes Labviews Solaris to exit completely.
I have an external lib which VI's make calls to.
When my function follows the error path, it makes a
call to another lib which does an exit(11).
This in turn causes Labviews 6.0.2 (Solaris 8).
I have the same libs on NT, and Labviews gives a popup
dialog with an error string.
Anyone know how to prevent Labviews from exiting???
I cannot change the 3rd library.
Thanks!
(3,000 Views)
You might try to install a signal handler. I don't remember the syntax,
but you have to have a C style function pointer, and you call something
like InstallSignalHandler.
You might want to install it, call the faulty function, then set it back
to its initial setting.
Greg McKaskle
(3,000 Views)
