Hello. Is there a maximum number of traces that can be displayed in a Hypertrend? I can successfully display 8, but if I add any more their value shows up as NULL.
The same thing happens in MAX at first, until you right-click a trace that is not displayed and change from Hide to Display. I guess I'm looking for a similar feature in the Hypertrend object in DSC. I tried using a property node with "Visible" for each trace, but no change. The database does not seem to be corrupted, and the tag values are fine in tag monitor.
I have very little experience with Hypertrends. Any suggestions short of using another type of graph?
Beth
