what's the meanning of "bad status" in DSC alarm config for Shared Variable?
as the title
LabVIEW 8.20程序设计从入门到精通已经出版,敬请关注!
欢迎访问LabVIEW学习乐园: http://labviewstudy.blog.edu.cn
(4,182 Views)
Bad Status alarms are about the states of the Shared variables themselves, as opposed to the data-value (High/Low) of the Shared Variable.  Example of bad status can be a communication state of the Shared Variable binding, etc.
-Khalid
(4,179 Views)
Can I read the quality  of an OPC tag which binded with a Shared Variable by using this  "status"?
(4,177 Views)
I am not sure -- for that, I am guessing you will want to look at the error codes (warnings, actually).  Unless of course there's a comm error which you should see as a bad status.
-Khalid
(4,161 Views)
