I HAD A DATA TRANSLATION DT3010/32 HOW CAN I USE LABVIEW AND WHICH VERSION
I NEED TO MEASURE 7 THERMOCOUPLES AND 7 RESSURE TRANSDUCER FOR MY PROJECT ICAN AFFORD FO NI DAQ THEY R TOO EXPENSIVE FOR THIS PURPOSE SO I PURCHASED A DATA TRANSLATION DT3010/32 DAQ ON  ABAY WHICH HAE16DI.NOW I NEED TO KNOW HOW TO USE LABVIEW WITH THIS CARD
(3,612 Views)
The support page for that company (isn't Google great?) indicates that LabVIEW software is available, for a price. Alternatively, you can use the .NET connector they have, and call that library using the .NET functions in LabVIEW.
Oh, and please turn off your caps lock.
(3,607 Views)
Hi
You need to install labview and NI DAQmx drivers. Then i think you would require the installation of the drivers of your card for labview.
If that is not possible then call the drivers which are available with the cards in labview using CallLibraryFunctionNode.
Regards
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,573 Views)
No. The installation of DAQmx is only required for NI data acquisition boards.
(3,569 Views)
i don't understand what u said, i can't find an answer in it.kindly help me.how to use  DATA TRANSLATION DT3010/32 with labview.thank for ur efforts
(3,544 Views)
Did you click on the Data Translation Link? Go there and click the Pricing tab. There is a button there to purchase the LabVIEW driver.
(3,533 Views)
