I am getting error "DSCENGINE.EXE had generated error and will be closed by windows"
Configuration of my PC is
OS - Windows 2000 professional ver 5.00.2195
Software - Labview DSC Runtime 6.02 with fixes applied.
RAM 256 MB
Hard disk 20 GB
I am geting this error even if I run DSC Engine with default.scf file.
I had tried it running through Tag Configuration editor and by running DSCENGINE.EXE through explorer. I am getting same error.
Can anyone sugggest possible reason?
(3,488 Views)
Uttam,
could you be more specific about the error?
Is it a crash in DSCEngine.exe?
If so, could you turn on to log the crash dump/Dr Watson file for Windows 2000 and attach the Dr Watson log file?
Brainstorming:
*Is your database totaly corrupted? - Delete all the files in \data folder (or wherever the default.scf is configured to log the data) before you start the engine.
*Is the default.scf file corrupt? - Create a new .scf file with maybe one Analog Memory Tag and try to start the Engine.
Otherwise, a more descriptve error would give maybe other ideas.
Hope this helps
Roland
(3,488 Views)
I have same problem in Windows XP pc with DSC runtime 6.1 with all fixes and patches.
(3,488 Views)
Can you be more specific and give full details of the crash. What's the error message, if any, etc.
Thanks.
(3,488 Views)
