I am looking for some information on ELAN protocol for Siemens analyzers and also some information on AK protocol for California Analytical Analyzers. Mainly I need a starting point to communicate with these devices for labview.
The NI USB-485/1 has a 9-pin D connector with a standardized pinout (you can find the pin listings either in the documentation that came with the device, or online).  Here's a handy NI Serial Quick Reference chart.
The ULTRAMAT has an RS-485 connector as well, if it's like the OXYMAT, it's also a nine-pin D.  The ULTRAMAT user manual should include that pinout.
No, you'll need to make a cable between the two...  May I suggest, get yourself one of these adapters from L-com.  Then it's just a matter of jumpering between some pins (see below) inside an adapter shell.
Even though the NI-Serial driver offers choices between two-wire and four-wire operating modes (and you will set it for two-wire auto mode), the field wiring is not bridged internally for you.  On the NI USB-485, there are four pins labeled TxD+, TxD-, RxD+, and RxD-.  On the ULTRAMAT, which is ONLY two-wire, there is only a single pair of pins, labeled RD/TD+ and RD/TD- (or maybe they use P and N, I think).
You bridge TxD+ and RxD+ together at the NI port, and wire that to the ULTRAMAT RD/TD+ (or P) pin.  You bridge TxD- and RxD- together at the NI port, and wire that to the ULTRAMAT RD/TD- (or N) pin.
Lastly, you connect the ground pins offered at each end.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 201 of 281
(2,984 Views)
Here is a quick copy of my pinout notes; seems to be working fine thus far.
NI USB-485 to Siemens Ultramat 23 Signal Converter
Message 202 of 281
(2,936 Views)
So, "working fine" = LabVIEW driver code is requesting and receiving measurement data from an ULTRAMAT?
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
Message 203 of 281
(2,953 Views)
Yes, your LabVIEW driver code is requesting and receiving measurement data from the ULTRAMAT.  I will update this post with any pertinent details as I progress with my project.
Thanks for all your help.
Kevin K.
Message 204 of 281
(2,944 Views)
Here is a quick picture of my pinout notes.
Message 205 of 281
(2,934 Views)
GND at NI USB-485 should be Pin1 NOT Pin2.  Yes, it did communicate with the incorrect pinout.
Message 206 of 281
(2,902 Views)
Some additional details to message 97.
Use D0 (hexadecimal) for default Source Address; use 10 (hexadecimal) for Target Address to get CO, and use 11 (hexadecimal) for Target Address to get CO2:
Do not forget to use RS485/Wire2 for RS-485:
Message 207 of 281
(2,880 Views)
Hi Mr. David Boyd
I too am in need of some examples for communicating with a Siemens FIDAMAT 6 using RS-232 or RS-485. To date I have not even found a command reference manual for FIDAMAT. I read from earlier posts that you have developed a set of VIs for this.
Would you be kind enough to send me these? Thank you! My email is raghu.nmj@gmail.com
Sundaram Raghuraman
Carmel, INDIANA
Message 208 of 281
(2,821 Views)
I also am interested in the driver for the CAI 600-series, if it's still available. Thanks in advance!
Message 209 of 281
(2,810 Views)
Attached is the library that needs to be installed into LabVIEW for the CAI 600P. You should be able to make your own VI from there, good luck!
Message 210 of 281
(2,809 Views)
