I am trying to create channels twice on the same card, ie 4 counter inputs and 3 counter outputs
Just to verify your last message, did you mean to say you can generate and read from the same counter Card?  Because I am using different counters.
Also if it is an issue with not being able to generate and read on the same counter card,  How come I have been able to generate and read analog inputs and outputs on a USB-6218?
Thanks for the help
Message 11 of 12
(854 Views)
Yeah, you should be able to generate and read from the same counter card using different counters. You just can't generate and read from the same counter onboard the counter card.
Message 12 of 12
(853 Views)
