Probably by changing the data type that lvdaq.dll expects to write to is causing the crash. I can't test this since I have only 6.1 installed now. In any case, since the daq card is only 16 bits, the single precision is probably adequate for AI Buffer Read. If you do need the greater precision later on, you should be able to change representation in any one of the upper level VIs.
