I am using the "Menu Selection With Events.vi" example alongside other while loops, When I select exit from the new menu it stops the other while loops but not the menu/event while loop
The event driven menu example works fine and I've integrated it into my application. I have built in simple local vars to link menu selections to existing GUI buttons. The problem is that I cannot get the File-Exit menu option to switch off/terminate the application. The [1] "Stop": Value Change panel of the event structure simply switches off the other while loops but leaves the event while loop running. Add a while loop to the axample using a local var from the event while loop to terminate 2nd while loop to get the effect.
Help appreciated, Chris
(3,390 Views)
Post your code so that I can see what is going on and I should be able to help you.
Joe
Joe.
"NOTHING IS EVER EASY"
(3,390 Views)
Hi Joe,
Thanks for the offer. The menu code should be capable of terminating the entire application when the user selects File - My Exit. I did a bit of extra work and found a possible solution, please have a look, is it ok? Suggestions appreciated.
Regards, Chris
(3,390 Views)
If your menu tag "Exit" case, assign "True" to your "Stop" variable.
-Joe
(3,390 Views)
Attached you will find a modified version of your VI.
I documented what I did on the block diagram.You were right on you just needed to add a variable with a true wired to it.
Have fun with it.
Joe
Joe.
(3,390 Views)
Glad to help.
Love labview, live labview
Joe.
(3,390 Views)
