how to get second instance of exe file in W2k
When I build an application into exe, I can run it only once. When I try to run it second time, windows makes the first instance an active one. I would like to have second instance running as well. How to make that?
Shat I make my vi reentrant? Will it help?
thanks in advance
Pawel
(2,734 Views)
Hi Pawel,
Check out the link below. Yes, I think making the vi re-entrant is the right direction..
Although the link below was for TestStand, it may shed a light to a solution..
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000012BC0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
(2,734 Views)
Hi
For a quick and dirty solution (and If you want to run only a few instances), making a copy of your exe might work.
PJM
vipm.io | jki.net
(2,734 Views)
