11-16-2007 03:17 PM
11-16-2007 03:30 PM
11-20-2007
01:32 AM
- last edited on
12-15-2025
04:19 PM
by
Content Cleaner
Hi bhuff,
One of the main reasons for having memory issues is array size. I would suggest going through the following KnowledgeBase and the different links within it. This may also help. One more important question which may help is the operating system and the version of LabVIEW you are using. Hope this helps.
11-20-2007 01:59 AM
hi all,
@Nitin: Your link doesnt work! page not found
I have the same Problem of bad using the physical memory. I want to convert a large tdms file to an ascii. While reading the TDMS-properties and converting the binäry file to an ascii file using a express vi the momenry grows to 2GB. Only reopening the programm make the momery going down! How can i handle the convertion by flushing the momery after a block is writen to the ascii file??? maybe i should avoid the express vi??
I m using a 1,7 Celeron with 500 MB Ram :-), but saving the TDMS files with 1 MSample/s does work fine!!! It uses less memory!
11-20-2007
02:05 AM
- last edited on
12-15-2025
04:20 PM
by
Content Cleaner
Hi All
Sorry about that. They were pointing to the internal database.I've linked the below post properly. It should work now.
