Peak to peak time detection
I am trying to detect the peaks of 30 cycles of a waveform. I want to detect the highest peak in each cycle and then find the time interval between two successive peaks. How do i do this?
(3,948 Views)
Try the Waveform Peak Detector function (found in Waveform > Analouge Waveform > Measurements > Wfm monitoring ). See attached picture.
Sture
Message Edited by sture on 11-19-2007 03:57 PM
Message Edited by sture on 11-19-2007 03:58 PM
Message Edited by sture on 11-19-2007 03:59 PM
(3,924 Views)
Thank you for the help!! I am glad that it is working for the amplitude detection, but to find the 'time between' I could not program it. Can you tell me what the first block in the picture is all about. [the block before 'peak detect'] You have specified certain values as 33,1000 etc. It would be good to get the details about these. At the same time if possible can u please attach the VI itself so that I can self check on the parameters.
Note: The input signal I am feeding is a real time ECG thro a circuit rigged up on NI ELVIS. I am getting the ECG waveform with a good gain.
(3,905 Views)
Here is the vi (LV 8.5). The first vi is waveform > Analouge Wfm > Generation > Sine wfm.vi. I used it to show the function of wfm peak detector. In your case, I suppose you have to convert your input signal to Labview wfm. I don't know what NI ELVIS is so I cannot help you with that conversion, anyone else ?
(3,892 Views)
