I am working on a CIN that takes in a string and returns a
n array of short ints (after applying a struct cast onto the string pointer). When I generate the code, the array has a dimension of only 1. Do I have to dynamically allocate the other elements or can I simply dimension the array the way I want in the CIN?I run labVIEW7 and use Msft visual C/C++ version 6 compiler
(2,435 Views)
n array of short ints (after applying a struct cast onto the string pointer). When I generate the code, the array has a dimension of only 1. Do I have to dynamically allocate the other elements or can I simply dimension the array the way I want in the CIN?bmfstop wrote:
> I am working on a CIN that takes in a string and returns an array of
LabVIEW memory is dynamically allocated and resized. The array LabVIEW
passes into your CIN can be any size from 0 elements to umtien elements
depending how you initialize the left side terminal of the CIN.
To be safe you should do following instead.
MgErr CINRun(LStrHandle *arg1, int32 *arg2, TD1Hdl *Array)
MgErr err;
TD1* ptd1;
DebugBreak
currentMessagePointer = (GRETSMessage*)arg1;
/* Make sure the array holds enough memory space to fill in data */
err = NumericArrayResize(uW, 1, Array, 51);
if (err)
/* report some error somehow, but preferably not through the
return value of the CINRun function */
return noErr;
ppptd1 = **Array;
ptd1->dimSize = 51;
MoveBlock(currentMessagePointer, ptd1->Numeric,
51 * sizeof(uInt16));
return noErr;
But you could also get the same functionality through use of the
typecast function as in attached picture.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,434 Views)
