coordinate system translation from screen coordinates to stage coordinates
I realize this is not truly a LabVIEW question, but I'm hoping for suggestions.
I have a digitized image of a sample on a 3 axis stage. The user selects "paths" for a drill to take along the surface of the sample. On the image, 3 reference points are identified. The stage posititions (x, y, and z) corresponding to these points are then identified.
I need to now convert the coordinates of the paths to the stage coordinate system. Are there any LabVIEW vi's that are suited to this need? I have IMAQ vi's but not very experience with these yet. Suggestions much appreciated
Tim
(2,997 Views)
Hello Shan:
Were almost have the same problem but mine is for a AOI handler with a robot arm which I need to pick (x,y) pairs along the work envelope. Anyway, for the most math part it will involve are coordinate transformation from a "mouse coordinates" to "real world coordinates" and your image processing textbook (I use McGrawHill Computer Graphics by Hill) will outline both the code and the math but LabVIEW will not have a facility to do with an actual VI instead you have to use the array manipulations and treat them coordinates as matrix elements. There is a Math VI and G-Math VI or a MatLAB call you can use for coordinate matrix manipulations as long as you have the math quite figured out in paper already.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(2,997 Views)
Dr. Berns,
Thanks very much for your reply. I was hoping that it would be a common enough task so that LabVIEW might have something along these lines already done. As you say, once the math is figured out, I'm sure I can get it implemented in LabVIEW. It's the math that I need help on.
I think I found the text you referenced here. Can you confirm that this is the text you are talking about? Thanks for your advice.
Tim
(2,997 Views)
