09-08-2005 07:35 PM
09-08-2005 08:06 PM
If you're not seeing a squarewave, what are you seeing?
What is the period of the squarewave?
What is your analog sample rate? (There's no fooling Mr Nyquist.)
Mike...
09-09-2005 08:08 AM
Thanks for your reply.
I got a straight line with some noise-like tone on the screen. When I changed amplitude, I saw the voltage level changed. I did try different frequency from 1 to 100K. There are some changes, but they are not square wave.
Is it because I am choosing emulator as target? With emulator I can not read and write to I/O port?
jason
09-09-2005 03:38 PM
Could it be that you are sampling so fast relative to the squarewave repetion frequency that all you're seeing is the "high" level? Also can you see the squarewave running the test panel in MAX?
Mike...
09-10-2005 04:54 PM
09-10-2005 08:06 PM
Doesn't make any sense that I can see right off hand. But if it's working... What do the connections look like at the signal-generator end of the wire, any chance that could be backwards?
Mike...
09-11-2005 09:22 AM
09-12-2005 10:21 AM
