popup-window doesn't open
Hello people!
Can somebody help me to find out why if i push the button "Zeigerdiagramm" in my program the pop-up window of the Sub-VI doesn't open.
The other buttons do that!
Thanks a lot for your answers!
My program was written in Labview 6.1 (Basis Package), therefore I can't use the event-structure. That also the reason why my program doesn't look very well!:-(
(3,319 Views)
Hallo Gnurt
Anhand des Wortes "Zeigerdiagramm" nehme ich mal an, dass du Deutsch sprichst.
Zu deinem Problem - stimmen die Einstellungen für das Sub-VI? Du kannst das überprüfen, indem du auf das Sub-VI rechts-clickst und dann Sub-VI Knoten Setup (oder so ähnlich, ich habe ne englische Version) auswählst.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,313 Views)
Some sub-VIs are missing in the zip file you posted, so I couldn't run it.
I don't know how you coded you VI, I know at least 2 different ways to proceed to get the front panel when the VI is called.
The easiest is to open this VI, hit "crtl+i" key-shortcut, choose "Windows Appearance", click "Customize" and enable the box called "Show front panel when called" (and maybe also "Close afterwards if originally closed").
I'd be surprised if this doesn't work.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,309 Views)
hello,
thanks I've just  found my fault. You all answer so fast. Thats really a good Forum!
thanks thanks,
(3,300 Views)
"When everyone gives a little bit, each one receives a lot" Smiley Wink
French proverb
you're welcome
Epictetus
Antoine Chalons
(3,295 Views)
