I can't find "DAQmx create virtual channel.vi"
How can I convert a "Channel" to a "Signal" ?
(8,105 Views)
If you have installed the NI DAQmx Device Drivers, In LabVIEW, you will find this function in the location shown in the pic attached
You cannot! Smiley Wink
Gramatically and Electronically, you can only 'read or write'  a signal on a 'relevant' channelSmiley Very Happy
(8,103 Views)
Sorry but I found no function here...
(8,085 Views)
As I said, install NIDAQmx drivers that you will find here
NI-DAQmx, 8.3 should be fine for you
Message Edited by devchander on 10-11-2006 11:43 PM
(8,080 Views)
