I can't run my LV program twice or save it
Hi,the problem is:
It's all right the first time I run the program(main.vi), but if I stop it and run again, the error happens and the program is auto closed(NOT by my program).
When I save it, two dialoges pops up,and one says:
Insane object at FPHP+DC in "main.vi"
{dsitem}(ox400):panel(FPSC)
The other says:
failure:"fpsane.cpp",line 269
Labview version 6.0
(2,506 Views)
"Insane errors are not due to your programming. There are several good pages on the NI site that discuss solving these errors. Goto www.ni.com >> support >> advanced search (it is at the bottom--click on the words). This lauches the best way to search the site because under option 2, you can limit your search to resources of interests. Enter insane in the all the words field and search everything. One of the first hits is a knowlegbase that discusses solving this issue.
Hope this helps,
Nick
(2,506 Views)
