Problemi d'installazione col driver NIDAQ
In un'applicazione basata su AT-MIO 16 E, PCI32HS e PCI7530, si riscontravano frequenti crash dovuti alla gestione della scheda 32 HS (NIDAQ 6.8). Dopo vari ed infruttuosi tentativi di installare Nidaq 6.9, si è passati alla Nidaq 6.9.3 con pieno successo.
(2,510 Views)
Hi all,
(for non Italian Speakers) the above message is a feedback on how the installation of the NI-DAQ Driver version 6.9.3 solved an issue a customer was experiencing with PCI-DIO-32HS and NI-DAQ 6.8.
Thanks to the person who posted this message.
Also, next time consider submitting your questions/feedbacks through
http://www.ni.com/ask
Alessio D.
National Instruments Italy
(2,510 Views)
