I cannot build an installer for my program
Accepted by User321
Do you get the same error if you do not include any additional installers?
Arev
Certified-LabVIEW-Embedded-Systems-Developer_rgb.jpgCertified-LabVIEW-Architect_rgb.jpg
Message 21 of 31
(4,115 Views)
Do you see where it says Installer Source Location? One or more of those paths will be empty or the installer will not be there.
Message 22 of 31
(4,103 Views)
That was it. That worked like a charm.
Thank you
Message 23 of 31
(4,088 Views)
Well, you might be able to create the installer by excluding everything but your exe will need them to ruin.
Message 24 of 31
(4,068 Views)
According to the images showing Additional installers, the only installer included was LabVIEW Run-Time Engine. LV RTE is required to be on the machine, for proper operation of the application. But if LabVIEW, or LV RTE is already installed on the PC, the application will function without any issues.
Arev
Message 25 of 31
(4,054 Views)
Then the op is incorrect in saying he uses GPIB and VISA?
Message 26 of 31
(4,038 Views)
I do use GPIB and VISA. That is how I communicate with my instruments.
Message 27 of 31
(4,021 Views)
Then you must include those in your installer or install the drivers separately.
Message 28 of 31
(4,015 Views)
I think it worked because LabVIEW was already including those installers, so it didn't need to be an "additional" installer. Since I didn't use any additional drivers or components, I didn't need any additional installers.
Just a guess.
Message 29 of 31
(3,986 Views)
Have you actually tried to run your program on a pc where nothing has been previously installed? That's the true test of whether the build works.
Message 30 of 31
(3,975 Views)
