I cannot open vi file
I downloaded all files from http://code.google.com/p/aeroquad/source/browse/#svn%2Ftags%2FAeroQuadConfigurator_v2.3
then I open in LabVIEW 2010 but it cannot open correctly there is a few error.
When I ignore them I cannot run this project.
This image is the error notificaiton.
How to fix this problem?
(2,832 Views)
Try downloading the llb from a different subversion rev.
(2,799 Views)
Hey,
When you get errors like missing VI ect its likely because the .llb or VI does not know where some of the VIs that are within the VI are located. I would make sure you download all the files in the Source Distribution as these might be some of the files required for the main VI to function.
http://code.google.com/p/aeroquad/source/browse/#svn%2Ftags%2FAeroQuadConfigurator_v2.3%2Fbuilds%2FA...
(2,760 Views)
