trouble synchronizing all 20 channels of Fluke Hydra 2625A data logger
I am using Labivew 8.5. I connected a hydra datalogger through a serial (RS232) connection. I have installed the driver and made it to work with 20 channels. However I am having a little trouble synchronizing the datalogger. As I read the values from the datalogger and write them to a file, some of the values are not being recorded. Is there anyway I can get it to synchoronize this without skipping any reading.
Waqar Iqbal
(3,203 Views)
Hi Waqar,
Unfortunately the 2625A driver isn't NI Certified, and thus I can't provide much help with that particular driver. Hopefully there is someone else on the forums who has experience using this device/driver.
Justin E
National Instruments R&D
(3,179 Views)
Hello:
I am a newbie to LABVIEW. I want to do some quick temperature measurements with J/K thermocouples. Downloaded the driver for 2625 from NI's website.
Not sure how to proceed?
Help needed! Thanks
(2,927 Views)
Hi Photon22,
You might want to look in the pre-made examples in the LabVIEW Example Finder. Under Hardware I/O>DAQmx>Analog Measurements>Temperature, there are several pre-made VIs for reading in temperature data. Also, as Dennis Knutson mentioned to you here, the 2625A driver itself should contain some instructions on use.
Andy H.
(2,903 Views)
