I cannot resize any object inside a tab control and the tab control itself
Hi all,
from this morning I notice I cannot still resize the object placed inside a tab control neither the tab control itself.
I have some objects (controls, indicators, etc) outside the tab control and they're resizable (I can see the dark blue squares and I'm able to shrink/enlarge the object); instead, any object inside the tab control are not yet resizable (when I select it the dark blue squares are not visible and I cannot access to the object properties by clicking with the right mouse button over it). If i access to the object's properties from the block diagram, the apparence->size frame is gray and I cannot edit any size fields.
It seems something was changed when I try to set the minimum window size and the windows appareance in the VI proprerties but I restore the previous values...
How can I fix this problem?
(4,527 Views)
could you send your vi or at least copy and paste your control in a vi and send it
(4,521 Views)
Accepted by topic author Lucast85
Make sure , Tab Control is not Locked.
Ifthe Tab Control is Locked Resize is not possible
@Lucast85 wrote:
Hi all,
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,513 Views)
Yes, it was blocked! Probably I accidentally blocked it.
(4,504 Views)
