I cant use vit files in application.exe
Hello al.
I am using vit files for call my indicators. Its working in my vi perfectly but when i try build exe with application builder, Vit files isnt work.
How can i fix this problem? You can see my call vit method from attachments.
Thanks.
(5,207 Views)
Several years ago, we were also using .vit files to allow us to decide, at run time, which file to run.  Worked fine in Development mode, failed in the Executable.  What worked for us was abandoning the .vit and VI Server and using, instead, the Asynchronous Call routines (found on the Application Control palette).
(5,165 Views)
Asynchronous Call by Reference is definitely the new/preferred way for launching multiple instances of the same VI or running different VIs dynamically (either from a static VI reference or dynamically loaded from disk).
It IS possible to create clones of .vit's and run them dynamically in an executable but you have to be careful about the paths etc. I can't remember from the code I saw exactly how it is done but we have applications where it is done in an executable (but now we use ACBR).
(blog)
(5,155 Views)
VITs are the old and busted, the new method is what others have mentioned, asyncronous VI calls.  Here is an example I made a while ago which demonstrates how it can be done without bothing with the file path to the VIT on disk.
http://forums.ni.com/t5/LabVIEW/building-an-executable-with-vits-with-Labview-2011/m-p/2384984#M7404...
(5,125 Views)
Thanks for your helps.
Now i can call my vit files with Asynchronous Call function in my main vi.
But my application.exe still cannot call my vit files.
You can see my vi properties, caller vi and error screen from attachments.
(5,111 Views)
Accepted by YFA
I'm not sure if this is your problem, but don't use a VIT, just use a VI set to be reentrant.
(5,108 Views)
Yes You are right i changed all vit files to vi and its fixed.
Thank you for your helps.
(5,103 Views)
