I change dt, but should the frequency change???
I have a Multifunction DAQ Card, and I need to produce a 200 Hz signal. The code I attached is really simple, but I am not getting anywhere near the resolution I need at 200 Hz. I change the dt value, but the frequency does not change whatsoever. Shouldn't it be that if I double dt, the frequency should be half of what it was?? If I want a 200 Hz signal don't I need a minimum dt of 1/200*2 = 0.0025 s?? Help!!
(2,765 Views)
first of all you don't need to create signals in loops like you did it in your example. You can use signal generation VIs, which will do all the job for you, from
Functions->Analyze->Waveform generation
or
Functions->Analyze->Signal Processing->Signal Generation
palettes.
As for your question you need to use dt LESS then 1/(200*2)=2.5 ms. This is very simple. If frequency is 200 Hz then the period of signal is 5 ms. To generate this signal you need at least 2 points corresponding to its maximum and minimum so the minimal value of dt is 2.5 ms. If you want to generate goodlooking sin wave you need more then 10 points on one period.
So if your waveform has N points and corresponds to K periods (N/K > 2) of the wave with frequency F then
dt=(K/N)/F.
Goo
d luck.
Oleg Chutko.
(2,765 Views)
