Problem with Spline Interpolation
Dear friends,
I've a problem with the Spline Interpolation which returned the error code -20049. I've tried in several ways such as delete the repeat data out, but it didn't work. If anyone can help will be very appreciated.
Thank you so much,
(3,266 Views)
The spline interpolation expects your x-values to be all different (and monotonic). However in your data set the x values at index 122 and 124 are identical (and also x(122) > x(123)). If you correct for this the interpolation should work fine.
(3,266 Views)
