I couldn't find how to integrate CDB with DBL in front panel as a single array
I am working with a LabVIEW example 'Matrix Fundamentals' in which I can see both DBL and CDB data types in the block diagram but both are connected as a single front Panel object. How can we make that?... I couldn't solve this. Please help me out. Thank you in advance.
(2,547 Views)
Accepted by manideepj
You cannot, they have different datatypes. You could format each as a string in a desired format and use a 2D array of strings (or preferably a "table") as indicator.
(2,510 Views)
Thank you so much
(2,494 Views)
