I couldn't find it inside string and array functions
(1,907 Views)
Accepted by bahadirozan
Hi bahadirozan,
this is the "decimate array" node. See attached picture:
Greets, Dave
(1,893 Views)
Thank you so much Sir. I had found it before. If it is decimate 1D array, I have a problem on this VI. There are four connectted lines on the array, but there are three connections as feature for decimate 1D array. How is it possible? Ekran görüntüsü 2023-06-28 141049.png
(1,874 Views)
Hi baha,
Use AutoCleanup on your VI!
(We cannot edit/debug/run images with LabVIEW!)
(1,861 Views)
https://dl.cdn-anritsu.com/en-us/test-measurement/ohs/10450-00040AC/index.html#page/Programming_Comm...
I am already working by examining the picture. I don't have prepared VI.
(1,854 Views)
Hi bahadirozan,
In this case you should ask Anritsu for a cleaned up version of that example VI!
(Or ask for explanations…)
Just an educated guess:
  • the output of the device read function goes to the input of the DecimateArray function
  • the two outputs of DecimateArray are wired to those two indicators (Data1/2) and to the FOR loop…
(1,848 Views)
Qestit Systems
Certified-LabVIEW-Developer
(1,759 Views)
